Switching vibration off?
L_M
Does anyone know is it able to switch off vibration and how? Yes, it's able to switch off when calls come but I'd like switch it off for whole.
(Apologies, if this theme has been discussed already.)
profile.country.RO.title
_alexdon_
I don't quite understand. For now, there is no silent mode (without vibration). That has been asked before and 5.1.1 has a "fix".
alexdon
6 REPLIES 6
Thommo
You have to switch it off in Sounds and also keyboard settings like vibrate on touch
L_M
Yes I have made those moves and it's working, when I type there is know vibration or when I have arriving calls. But when I receive messages and announcements and sounds are off, the vibration doesn't go off... Can You advice with this problem?
Thommo
Maybe @alexdon or @uliwooly can help as they use LP - I'm staying with KK firmware
Uliwooly
@L_M
if you lower the volume to vibration > press volume down again > allow exceptions
_alexdon_
alexdon
L_M
Hey, great! That answer solves my problem, I need to update the fix. I have tried the volume button and settings, but there just isn't silent mode without vibration. Thank You!
