Too much noise in camera after M update
jack007
Hello team Xperia,
Yesterday i updated my m4 aqua to the marshmallow firmware. Update is very good as compare to 5.0 lollipop.
But after using the camara I was very worried that camara quality is too low as compared to lollipop version.too much noice is in photos can you please explain give a proper answer...
Tags (1)
Uliwooly
@JACK619
The update was just released, if there are bugs or issues, they might be addressed in a future update, keep in mind that this is a user based forum, don't forget to send your feedback to Sony >>> Local support
4 REPLIES 4
Uliwooly
@JACK619
netto
My M4 with latest MM update give me much better camera quality with Superior Auto mode and slightly faster photo capture speed, I don't need use Manual mode anymore.
Mahigist
Yes ,completely agree with #JACK, camera goes darken, also the speaker volume decreases, these two issues i found after the marshmallow update.
jack007
Yes #mahigist you also noted, volume control (equlizers) are makes very unhappy...issue --- when playing sound with heavy bass..volume become down in speaker in earphones (Sony ex150) it's very noisy sound also on full volume hope next update (if they wants to give) will fix this..but all over UI and speed is better than lollipop. One more thing when disabling sim 2 in notification baar always show ls the disabled sim 2 indicator even if restarting...thank you
