Try uninstalling android wear software and then check the wifi.. did wifi start workin? if it did, would you care contacting sony and scream "fix it ASAP"?
Settings > about phone > diagnostics > test > test WiFi
I have and that made no difference.
I have contacted a sony support member and been told that it will have to be sent in for repair. Does anyone know how to get in touch with the escalations team as it is a phone I have had for only about a month after being a replacment for a phone that over a 3 month (roughly the same time as I had had the phone before that) period was "repaired" multiple times, which after each it had new problems.
Hi, I have the same issue. First the factory reset fixed the issue, but right after i installed android wear + motorola connect smart watch apps, the Wifi issue started. After starting wifi, it turns itself off immediately.... So I guess the wifi issues has something to do with android wear....
Do you also have android wear?
@Pikku-Y wrote:Hi, I have the same issue. First the factory reset fixed the issue, but right after i installed android wear + motorola connect smart watch apps, the Wifi issue started. After starting wifi, it turns itself off immediately.... So I guess the wifi issues has something to do with android wear....
And after uninstalling the android wear things from the phone.. TADAA.. wifi started working..
God i miss my old good Jolla phone, which i accidently broke:D
