@Zizolec But where did you get the information about xperias being limited to 1A at charging? EP880 and EP881 have 1500 mA output and work with all xperias.
@Alvyibnferoz You can safely use another charger, with higher amperage.
Yes, you can use a charger that delivers a higher amperage and it should charge faster. Remember to try and use original sony chargers for best charging experience.
I don't think so . Sony phone itself have a circuit to regulate the input amperage. normal AMP for Xperia is 850mA, maby it will charge with max 1A.
If so then it really. It's too low for a phone at this price.
I have Xperia M5, in my observation huge difference in charging depends on cable. If i use normal usb cable 80% takes up to 6-7H, on orginal cable it kaes about 2 H.
Yo can try app'k like
Ampere or Charger Tester (ampere meter)
@alexon so if i use 2A charger phone will charge approximate 2x faster right?
Another issue is that sometimes video won't play. Even YouTube app or Facebook app cant play video it stucks. Only fix i found is restart. Then all ok but after sometimes Same problem, no app can play any video and gif. Any solution to that?
