Hi @BOB20,
As Phy stated, Xperia M2 does not have the option to output sound through the USB port.
Hi @Mickey91,
Xperia Z3 supports outputing audio via USB as long as the DAC that you connect to uses Android's standard drivers. In some cases you may have to install an app specific for the DAC though so make sure to check the requirements for the DAC.
