Xperia M5 not updating to marshmallow
dx1
I recently tried to update my xperia M5 device to marshmallow through pc companion, the update was downloaded but when I connected my device through the cable then a messge appeared on the screen of my device which read that ''Unfortunately, update service has stopped''. Hence, I just couldn't update my device.
41 REPLIES 41
knightdeat
I do not have much English to denier or less , please help make my shame about the c kafayi
djebelcit1993
At least u got update ,on my xperia E5653 30.1.A.1.55  i still got no update i dont know is there any problem i should wait...
Emessi
Hello!
First of all sorry for my English,I'm French ( nobody's perfect.:smileyhappy:..)
I have a problem with the update to 6.0.I downloaded it , the phone began to install it but restart to the same version ( 5.1).I can't use Xperia Companion  becausethe phone is not recognized.
I sent my phone to Sony Care.Still waiting....
Muchakis1
Hello,
I am facing the same problem. I connect the phone to my PC, Xperia companion pops up and says there is a new update to 6.0 for my xperia M5. I click on update and it starts downloading, when it is finished it asks me again if I want to proceed, It then says preparing your phone and at the same time the phone shows an error message "update service stopped working". I also tried with the device turned off and holding the volume down button. I have restarted the phone a few times, tried in safe mode, I have also restarted the PC, nothing helps. It shouldn't be this complicated to update a brand new device I bought last month with lollipop 5.1.1 pre-installed.
Muchakis1
Hello,
I successfully updated my device by using these steps:
-Uninstalled Xperia companion
-Restart the PC
-Installed the latest version of Java
-Installed Xperia companion
-Connect the phone and select update
-Turned the phone off and followed the onscreen instructions
If it doesn't work try a different USB port on your PC.
Hope this helps.
Tyrell24
I'm in the same situation man! I'm waiting for the upgrade of my Xperia M5 e5653 to Marshmallow from 5.1 lollipop  Slightly_frowning_Face I hope it's fast
D-cpt
Same here. Some guys got it way back in July; we're still waiting. Slightly_frowning_Face
Czh13
I just got my Sony m5 out of the box and installing the Xperia system update does not work. It downloads and when I tap update, it starts updating for a bit, but after a minute or so it boots the phone and gives me an error. How to solve this?
NeoBeum
Enthusiast
Charge the phone above 50%
Update the phone via Xperia Companion on a computer
profile.country.PH.title
MarlonUk1
You can follow above suggestion or perform software repair using Xperia Companion, it will download the latest version and install it on your phone
