I need to backup my arc before sending off for repair, there is nothing on pc companion to do this and no app on my phone. I would prefer to back up everything including system settings, apps and media. Is there a way i can do this
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Don't forget to mark the Correct Answers & Helpful Answers
and also
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
thats great thanks, i was flapping a bit when i thought i was going to lose everything. My arc is only getting sent back for a cracked bezel above the light sensor so not sure why they need to wipe my phone anyway. But backup is sorted now, thanks for your help.
Anytime
I've been using Chrome to phone for a while now, even before I was suggested to try my phone explorer
but why my arc is incompatible..??:smileyplain:
why is this
my region..??
