- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have bought my se w980 in Jan 2009. Since then I have been facing one problem. Sometimes* when i call or get a call, it hangs. it hangs on its own for a while. and after ssometime it restarts on its own. It took 1 year to me to identify the problem as, it hangs when it gets a call from unknown number(if the number not saved in phone). it hangs if we call unsaved number.
That is my phone problem. So i thought, to update software. so I did phone repair using SE pc suite. It could not repair. the final message I have got is in the attachment.
Please, Please help me in this. As I am missing lot of important calls.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try SEUS on a different PC.Otherwise,try a Master reset and see if that solves the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So did you actually run the SE update service on your phone (not PC suite) and attempt to update or re-install the software?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes Chris, I did.
I run the update service on connecting to PC suite. By following the steps, switching off the phone. remove the battery and reinsert. and pressing C button while connecting the USB cable to system. The phone repair(update service) run for a while, showing the message(Downloading the phone repair... ) after sometime, It stopped. Showed the attached message.
Thanks Chris, for looking into this.
Regards.
Ratnaker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
try using SEUS , not the pc suite
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The repair option is different to SEUS, which you can download from this link.You don't need PC suite for this as it's a separate application altogether.
.http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w980?cc=gb&lc=en
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Chris,
Thanks for your valuable reply.
I have downloaded SEUS and tried with it. Still i have got the error. Phone battery was charged morethan 90%.
Please find the attached error.
Thanks again for looking into this.
Regards,
Ratnaker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you Very much Chris. That is very helpful response. I could succesfully update my phone.
Regards,
Ratnaker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
sir
was tryin the same as his phone as your instruction but still the same.
the phone no turned on.. as you said master reset... how..
because the phone is not turn on and only a light and a red light shown.
tq
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try re-running SEUS, because you can only do a master reset if your phone turns on.
