I updated my Xperia Play to Android 2.3.4, 4.0.1.A.0.283 using uliwooly-wooly's guide. Afterwards I get a message to update the software to 4.0.2.A.0.42. After downloading I try to install it. Except after it reboots it tells me the installtion failed. Is there any way I can resolve this?
or you can use flashtool again and install the latest update
http://talk.sonyericsson.com/message/131810#131810
make sure you mark the Correct & Helpful Answers
simple, repeat the process with Flashtool to repair your phone then use SEUS to update to the latest version, and this time do not unplug the phone too soon
Repair my phone with the Flashtool, huh? How would I do that? Just repeat the same process that I used to upgrade my phone?
exactly, just repeat the process all over, that will fix your phone
All right, I'll just do that then.
I will be sure to. Thanks for your help.
anytime, let me know if you need any more help
