I've been trying to update my Arc S via PC Companion for a few days now, but whenever I try to, I ran into the wininit.exe notification.
Being that file a part of the operating system, it doesn't make much sense to me...
I already re-installed PC Companion, but nothing seems to work.
My OS is Windows 7 32bit.
Here's a screenshot:
Hi, you can either perform the update on another PC/Laptop or use an SE Update Service.
If you are interested, here's the download link,
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe.
Hi there!
Thanks for the ultra-fast reply!
I'll try to use that exec you sent on the link.
Be right back to give you a follow up.
Thanks!
Oh, by the way, is there an uncomplicated way to perform a "Full-backup"?
No problem, I am fast because I am online ....
Didn't you do a backup prior to your unsuccessful update with PC Companion? By the way, I was updated to Android 2.3.4 without any backup, but phone was 'restored' (automatically) after the update. Anyway, you may want to have a look at MyBackup app.
Hiya,
It worked like a charm... The backup wasn't necessary, but we never know, do we?
My phone is upgraded at last, thanks to your help!
I don't know if you work for SE, but maybe it would be worth the effort to understand why this "Wininit.exe" warning shows up, being wininit.exe a critical Windows process... or maybe to place an "ignore" button on that issue.
Anyway, Thanks for the help! I had found similar answers on this forum, but i thought the executable could be model specific...
Glad that it worked out for you.
Nope, I don't work for SE, I am just a volunteer in this Forum.
To be honest, I have no idea regarding this 'Wininit.exe' warning, probably a search in the internet would help?!
Continue to enjoy your Arc S ....
I have had the same problem when trying to update my Arc telephone.
I tried following the link that you have supplied, but it does not lead to a specific download or application... it just redirects to http://www.sonymobile.com/
If I search for the software myself on the site, I end up with the same PC Companion Software, which, when I install it... causes a blue screen Windows 7 crash.
I have tried uninstalling and re-installing, but continuously have the same problem.
Are there any plans for Sony to debug the software and issue a new version that does work??
use this link
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
latest version of pc companion is http://www.sonymobile.com/gb/tools/pc-companion/
Thanks
I used the first link... update service. That has wworked perfectly
MIk
