Guys, for the past week i am facing a intermittent connectivity issue in my ray, My GPRS plan is enabled and spoke to the network provider for the settings, but the issue is whenever i turn my gprs on the little arrow mark never comes in the notification bar even if i wait for a couple of minutes nothing happens, so i restarted my phone and GPRS started to work fine and after 15 - 30 minutes the connection drops automatically. Its really a pain because it works only for little time, but not its not conencting anymore. What could be the cause? any suggestions?
Troubleshooting that i have tried?
1. Deleted the APN and manually added new APN by contacting my network provider
2. Restored my phones system settings ( After doing this the internet worked for a day and automatically dropped of, No its not even connecting :smileycry:)
No matter what i do its still the same! Any suggestion will be much appretiated. screenshots below.
Build Number : 4.0.2.A.0.62
I think its the latest build right?
yup its the latest firmware
Yes you are somehow right but my connectivity drops only when the yellow triangle appears. So i think my network provider has poor signal strength is that right? Adding to it today morning i kept the data on and its seems to be stable now.
Thanks nabeelraza. i think i may have to change my network provider!
no problem azhagarasu
and the problem is with network provider as i earlier said
yeah yellow traingle means no network and if happens often then ur gprs wont work propelry
Got it Thanks!
