I need help with my xperia ion lt28h..
After installing a .zip (Smooth ion) through CWM Recovery, my phone restarted n booted up normally to the lock screen. After i unlocked the screen, it went blank so I pressed the power button and the normal power off button (and some others) appears, so i power off the phone and it went to a boot loop.
I tried pressing the Volume up + power button and connecting it to flashtool by pressing the volume down button and inserting the usbto flash a new firmware but nothing appeared on flashtool
I tried the Volume up + power button again and again and still nothing.. I then pressed Volume up + power button again but longer and received 2 or 3 vibrations (i can't remember) and now the phone is just Dead. No Screen,No LED light, nothing :'(
I tried charging it for 2+ hours and tried connecting it to my pc to see if it does anything but apparently nothing happens.
Somebody please help me :'( This is my only phone and I have no other
Xperia ion LT28h
Firmware: 6.0.F.0.72 (LT28i 's Firmware)
Bootloader: Unlocked
And Rooted with Busybox installed
I know this is not the exact place to ask for help, but i'm really desperate
hey 03parth
What's the status of your phone now ?
try force restarting and shutdown
USB debugging is not needed for flashing, so don't worry.
Model: LT28i
Firmware:ICS 6.1.C.1.105
Status:
It is in OFF mode since last month. I cant turn it ON. While charging shows strong RED LED.
No response when pressing power on and combination button for soft/force restart.
After charging 16+ hours red led went off.Again try to turn ON but no response so charged it again so back with strong RED LED.
When try to flash it , i can get in to flashmode and flash process shoes 100% on flashtool and at the end flashtool says disconnect your device and turn on.For flashing USB debugging and unknown sources should be checked in setting.And when after flashing try to ON it wont start.
So please Nabeel find some solution for my ION , stuck in it for one and half month.
Man are you serious ?
You're phone has been in coma for over a month now and you still haven't get your phone examined at service center.
It's probably a hardware damage friend and the only option is to visit service center.
I have already sent it once for repair but they didnt find any hardware problem at all.
And even he can't even load ant firmware on my ION.
So I decided to turn ON by getting help from this forum .
It just shows only RED LED on charging.
I can get in to flashmode.
2 times my display was blinking for near about 5-7 min.
Is there any solution?
To be honest, there is no exact solution.
It's just that whenever a phone gets bricked, it charges really slowly. Moreover it's not detected/ flashed by PCC / SUS / Flashtool if the battery is low.
Now what you should try to do is, charge continuously for a day or so. Then flash it using flashtool and try to switch it on by force restarting it ( not the normal way )
Press and hold the power button + Volume Up button for
5 seconds > ( 1 Vibration ) Force restart
10 Seconds > ( 3 Vibrations ) Force shutdown
If this doesn't work then RIP Ion
No response from those combination.
Neighter getting 1 nor 3 vibration at all.
Nabeel, i am facing the same issue oyhens had faced.
After a long charging cycle ( around 4 hrs) its showing Red LED.
I bricked my phone while flashing a paranoid android rom ( Forgot to flash the boot.img and directly flashed the rom file!)
At least for now phone responds to long press of power and volume button (1 vibration n 3 vibration)
Keeping my fingers crossed to recover my phone
Will update the status..
Hi Nabeel,
My phone is still charging after 24 hrs..
is this normal?
Hi Nabeel,
This is the log of flashing i did. Please let me know if it was successful.. During flashing the LED turned Green and now i have put back the cell to charging.
I am hoping my phone will be alright !
10/034/2013 18:34:00 - INFO - <- This level is successfully initialized
10/034/2013 18:34:00 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00
10/034/2013 18:34:06 - INFO - Device disconnected
10/034/2013 18:34:10 - INFO - Selected LT28h / 6.2.B.0.211 / Generic
10/034/2013 18:34:10 - INFO - Preparing files for flashing
10/034/2013 18:34:40 - INFO - Log written to C:\Flashtool\flashtool_2013-08-10_06-34-00.log
10/034/2013 18:34:42 - INFO - Please connect your device into flashmode.
10/039/2013 18:39:47 - ERROR - Drivers need to be installed for connected device.
10/039/2013 18:39:47 - ERROR - You can find them in the drivers folder of Flashtool.
10/039/2013 18:39:48 - INFO - Opening device for R/W
10/039/2013 18:39:48 - INFO - Start Flashing
10/039/2013 18:39:48 - INFO - Processing loader
10/039/2013 18:39:48 - INFO - Checking header
10/039/2013 18:39:48 - INFO - Ending flash session
10/039/2013 18:39:48 - ERROR -
10/039/2013 18:39:48 - ERROR - Error flashing. Aborted
10/039/2013 18:39:49 - INFO - Device connected in flash mode
10/039/2013 18:39:56 - INFO - Device disconnected
10/039/2013 18:39:58 - INFO - Device connected in flash mode
10/040/2013 18:40:19 - INFO - Selected LT28h / 6.2.B.0.211 / Generic
10/040/2013 18:40:19 - INFO - Preparing files for flashing
10/040/2013 18:40:39 - INFO - Please connect your device into flashmode.
10/040/2013 18:40:39 - INFO - Device disconnected
10/040/2013 18:40:41 - INFO - Device connected in flash mode
10/040/2013 18:40:43 - INFO - Opening device for R/W
10/040/2013 18:40:43 - INFO - Reading device information
10/040/2013 18:40:43 - INFO - Phone ready for flashmode operations.
10/040/2013 18:40:43 - INFO - Current device : LT28h - CB5A1LLP49 - 1267-1661_R2H - 1252-5917_6.2.B.0.211 - WORLD_6.2.B.0.211
10/040/2013 18:40:43 - INFO - Start Flashing
10/040/2013 18:40:43 - INFO - Processing loader
10/040/2013 18:40:43 - INFO - Checking header
10/040/2013 18:40:43 - INFO - Flashing data
10/040/2013 18:40:46 - INFO - Loader : S1_Root_de72 - Version : R5C010 / Bootloader status : ROOTABLE
10/040/2013 18:40:46 - INFO - Processing kernel.sin
10/040/2013 18:40:46 - INFO - Checking header
10/040/2013 18:40:46 - INFO - Flashing data
10/040/2013 18:40:48 - INFO - Processing fotakernel.sin
10/040/2013 18:40:48 - INFO - Checking header
10/040/2013 18:40:49 - INFO - Flashing data
10/040/2013 18:40:50 - INFO - Processing amss_fsg.sin
10/040/2013 18:40:50 - INFO - Checking header
10/040/2013 18:40:51 - INFO - Flashing data
10/040/2013 18:40:51 - INFO - Processing amss_fs_1.sin
10/040/2013 18:40:51 - INFO - Checking header
10/040/2013 18:40:51 - INFO - Processing amss_fs_2.sin
10/040/2013 18:40:51 - INFO - Processing amss_mdm_efs_1.sin
10/040/2013 18:40:51 - INFO - Processing amss_mdm_efs_2.sin
10/040/2013 18:40:52 - INFO - Flashing data
10/040/2013 18:40:52 - INFO - Processing amss_mdm_fsg.sin
10/040/2013 18:40:52 - INFO - Checking header
10/040/2013 18:40:52 - INFO - Processing apps_log.sin
10/040/2013 18:40:53 - INFO - Processing cache.sin
10/040/2013 18:40:53 - INFO - Checking header
10/040/2013 18:40:53 - INFO - Flashing data
10/040/2013 18:40:55 - INFO - Processing system.sin
10/040/2013 18:40:55 - INFO - Checking header
10/040/2013 18:40:55 - INFO - Flashing data
10/044/2013 18:44:13 - INFO - Processing userdata.sin
10/044/2013 18:44:13 - INFO - Checking header
10/044/2013 18:44:13 - INFO - Flashing data
10/044/2013 18:44:23 - INFO - Ending flash session
10/044/2013 18:44:23 - INFO - Flashing finished.
10/044/2013 18:44:23 - INFO - Please unplug and start your phone
10/044/2013 18:44:23 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
10/044/2013 18:44:24 - INFO - Device connected in flash mode
10/044/2013 18:44:36 - INFO - Device disconnected
Ok Great update!
I plugged into charger after Flashing and my phone is up and running again!
Thanks a lot Nabeel and oyhens!!
Cheers!
