Android 2.3.4 4.0.1.A.0.283
http://forum.xda-developers.com/showthread.php?t=1279774
Special Thanx to Jozinek
Android 2.3.4 4.0.2.A.0.42
http://forum.xda-developers.com/showthread.php?t=1312475
and Xperiablog
More pix HERE
Hey after the update ,my xperia mini starts getting heated faster than before and I am unable to use Trackid ..
ny suggestions ???
it might get heated faster because you have multiple things running, like syncing more accounts
or something could've gone wrong
you can use
Update Service to repair it
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
K i'll try again and let you know .. but temme I have heard that u wont b able to use SE official apps like track id and all .. is it true ?
that's not true, since you are NOT installing a custom ROM it won't change anything,it will work just like it's supposed to
What about 2.3.5 ?
See you guy so happy with this updated
but is it possible with my sk17?
i also want 2.3.4 on my device too . can i?
it hasn't been released, as soon it is, I will create a new thread on how to manually install it if it's not offered by your network/country/region
Thank u,
hope you can make one for my network/country/region ( Cambodia ). Thz u
hey uliwooly..
sk 15and sk17 have different firmwares ??
but for the arc we can flash any..
like whether its lt15i or lt15 a ??
I don't have neither, but if I had the SK17 I would try to flash the SK15's firmware
