- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Demand 5 - KDL32-WD756 - Programmes won't play
Hi all,
Just acquired a new KDL32-WD756 which is running the latest firmware but it will not play any Demand 5 programmes. Just comes up with a message "Whoops! The programme you are trying to watch isn't currently available. Please try later" It does this for every programme and I know the material is available because my Roku streaming stick works perfectly over the sam internet connection. i-player and other streaming appps seem to work fine, it's just Demand 5 that doesn't
Any thoughts amidst the learned community?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Have you tried doing a "Refresh Internet Content" on the TV?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had the same issue, just unplug your tv from the mains and wait about 30sec then plug it back in and it should be working if it didn't a factory reset should work but you have to set up the tv again which is a pain so I would try the mains method first.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same TV and same problem here - since new 4 months ago. I've had everything done, including soft and hard resets (as mentioned above). The internet is fast and other Apps work as they should. Spoken to Sony a number of times but they just want to find something simple wrong with my TV - in vain. It is pretty clear that there is an incompatibility between this TV and Demand 5, but Sony won't pursue it.
