How can I tune north west tv programmes into a Bravia LCD Digital TV ? The settings menu does not allow it to be set to regions.
Hi there
I can only assume that the signal is too weak for the TV to pick up. Has it worked before? and recently?
cheers.
Thanks for your response. The signal is OK. The tv does not have a "set to region" facility when going into tune up. It ceases after setting language and country. So, instead of getting North West I get "telly-welli" ! I will check the position of the ariel.
