Sony Bravia KD-55XE7096 restarting
profile.country.SK.title
Robo222
Hi
please help me
the TV is restarted by pressing the [HOME] button and then pressing [RETURN] on the remote control
i have firmware version 8.673
now this version is unavailable on sony page
and i read on sony support firmvare version 8.674 fix this problem,
I can not install this update via wifi or usb
tv does not show me a new update for my choice
I tested everything according to the instructions on sony.com . many times
i try factory reset and after try find firmvare but nothing.
thx
10 REPLIES 10
Sean_Mc
Moderator
Hi there,
Can you make sure that your TV is set to receive an automatic software update.  You can find more details on this here.
Let me know how you get on.
Best wishes,
Sean Mc
Robo222
Hi
yes i am sure
there was no problem before the last update
thx
EdwinaU
Moderator
Hi Robbo,
Thanks for letting us know. We'll look into this for you and update the thread when we know more.
Best wishes,
Ed
batee5
Specialist
Hi Robo222,
Welcome to our community!
This is issue you described is a bit weird and will need further troubleshooting I'd say. If you have any external devices connected I recommend disconnecting them to test the performance of the TV without them. It's also helpful to disconnect the TV from the mains without turning it off to discharge any static.
You mentioned that you're unable to update the TV neither form the TV itself nor via a USB stick, could you let us know what exactly happened or went wrong? You'll find detailed instructions on this link on how to update your TV.
Regards,
Batee5
Robo222
hi
i need only fix this problem:
  • Resolves an issue where, under certain circumstances, the TV restarts when pressing the [HOME] button and then the [RETURN] button on the remote control
  • i start have this problem after actualisation fw to  v8.673
  • i think whit this actualisation is something wrong
  • beacouse sony deleted from his page
  • i try ewrithing really to fix this problem but nothing
  • bye
batee5
Specialist
Hi Robo222,
If you currently have FW v8.673 installed on your TV, you'll need to update it to v8.674 in an attempt to resolve this issue. If you're unable to update your TV via USB or from the internet itself, could you let us know what happens when you try to update via a USB? Do you get an error message or the update files are not recognised?
Regards,
Batee5
Robo222
hi
when I put the USB inside with the new update TV told me no update to choose
and with wifi its the same
thank you
bye
batee5
Specialist
Hi Robo222,
Here's a few suggestions you can try to make sure the files are properly downloaded on the USB stick to make sure the TV will recognise it:
- Format your USB to FAT32 or exFAT on your computer.
- Make sure to extract the downloaded files then move them to the root of the USB. That means it shouldn't be in any folders.
- Try different USB ports on yout TV and a different USB stick if possible.
Regards,
Batee5
Robo222
hi
look i work before in one company like a IT specialist , i try do everything
