Can connect web via ethernet but no longer via wifi - though it can connect to router - why..
HI there
Sorry buddy, but you need to provide much more information, for example, model numbers of TV? Any error messages? And any other information that might be useful for diagnistic purposes.
Sometimes a factory reset may assist, Also check that your firmware is upto date. Can you successfully 'see' your wifi network when its scanned? Do you have enough 'bars' on the signal strength?
Thank you
