Hello,
I have a big Problem after changing my defekt harddrive disk.
I don't know why.. it is gone to hell
My frind is also no good computer freak.
He gave me this job to solve his problem.
With the new harddrive disk:
After installing XP, the utility-cd outputed the error message: runtime error xx.
This error happens when i try to start the touch-pad (mous) utility from cd.
My question ist now, why the utility-cd ist not working after changing the harddrive disk
I hope i have explain relevant.
I do this job for my frind, because he think i can better english.
ciao
Have a nice day
Hi rene Thomas,
Download and install the pre-installed utilities and drivers for your Vaio model from Vaio-Link.
You first need to install Sony Utilities (Installer Folder 1) and then Sony Shared Library (Installer Folder 2) before attempting to install other utilities or drivers – assuming that the downloaded folder contains separate folders.
If you find that the download contains a single .exe file then run this prior to installing any drivers.
Hi rich912
thanks for your fast replay
Do you think that this porblem has nothing to do with the changing of the harddrive. In the Computer shop, the seller said that this error-message happens when the serial number of the harddrive has changed.
What do you think of this statement.
I can't belive that this statement is true. Is It?
I don't know what i have to do, i am thery confused.
I try to do your solvings.
Another question by the way.
Can the touchpad (mous) be a reason why the laptop freez sometime?
Have a nice day.....
Hi rene Thomas,
Hi Rich912,
The model nummer is
PCG-GRT816M
I have seen only one CD by my frind.
On this CD (autostart) apper a menu with some options of utility.
When i click on one of it came the message runtime error.
I think the problem is that.... i can not install one of this utilitys because the error message-box apper.
I try your 'Options' abov the first time next week.
My frind is at the moment on holiday.
But together we will bring this mashine in excellent 'Mode'.
My words are to 'low' to say how happy i've been for this support here.
With my 500 words in english is it difficult to explain technical ......
Thanks a lot
As soon
Hi Hi rene Thomas,
The pre-installed utilities download for the GRT816M contains a single file, Utils.exe. Running this should install all the utilities necessary for you to then install any required drivers either from the CD that you have or the pre-installed driver download from Vaio-Link .
I have a feeling that the recovery media for this model should consist of more than one disk, but here is a link to the recovery procedure.
