This may seem a stupid question, I have a RX511, how do you get inside, iVe managed to slide the top off wher e dyu go from there!!!!!
Non of the manuals give any instructions
Stand the case with the rear (where the ports are) facing you. On the right hand side at the top underneath a lip there is a release switch. Pull this towards you and the side of the case will come off.
If you have any more trouble PM me and I'll email you some photographic instructions.
This is a popular picture:
This comes from Vaio-Link's solution regarding memory upgrade:
http://www.vaio-link.com/common/addmem.asp?L=uk&ID=863
Once inside, you will probably need to unscrew the little screw holding the PSU in, then pull on the catch that holds the PSU in, flip the PSU over and then you can access the memory slots (easier than it sounds). At least this is how you do it on the 405
