Page 48 in the troubleshooting manual tell you how to re-install the utilities, it informs you to go to the C: drive and open folder Utilities But I cannot see this folder. Does anyone know if this is applicable to the K315M series? And if so where can I get the utilities data? This is starting from a virgin machine, i.e. rebuilt using the Sony recovery HDD method.
all my utilities are on the recovery disks. Hane you looked there?
Don't get any disks with this machine. You have an option to make them but I assume if they are not built using the HDD recovery utility then they will not be on any disks I create. I am not sure if this is unique to the K315M...cheers JD
Have a look in the start menu too.
You can download the Utilitys from VAIO-Link too.
Thanks folks, I think what I am trying to find out is if the utilities came with this series of machine and if so why are they not there in HDD recovery and if not then If I download them will they run on my machine? JD
It'll only run if theres a hidden partition I guess
Yes I have a hidden partition..i'll investigate further..thanks lo
