I've completed a clean install of Windows 7 Ultimate on my VGX-TP2 and have one last issue. I can't identify and locate a driver for the hardware device 'Multimedia Controller', which I guess must be the on board Hybrid TV Tuner card as MCE tells me there is no TV Tuner Card installed. I could go back and install Vista and then upgrade - but it would be cleaner to avoid Vista (and the bundled Sony utilities, which I've never used).
I've tried DriverBoost - this is a help - but this can't identify the tuner card type.
Has anyone successfully done a clean 7 install?
Have swapped the original noisy 500GB HD for a WD Caviar Green e-SATA 2TB drive - which has made the unit virtually silent.
I think you have an AVerMedia A313 MiniCard TV Receiver.
I would expect the driver to work with both Vista and Windows 7 but unfortunately the driver is missing from the download page for your model - Sony have sadly not included it with the driver download.
However, there is a Vista driver for the VGX-TP3S which should work on the download page for that model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGX-TP3S_B
There are also many free downloads if you try Google - some for Windows 7 - but make sure you get the correct driver. Try Googling for "avermedia a313". Was your TV Tuner a hybrid Analoge/DVB-T model, an Analogue Tuner or a Twin DVB-T Tuner model? There are different drivers.
Good Luck.
Hi, I want to swap out the HDD on my TP2 but can't get the thing open! I removed all the screws but can't see where the clips are to pop it open..
How did you swap out the HDD in yours? Did you find any photos for a teardown?
Any help would be gratefully received.
Thanks
hi ther i have the same problem device manager says no drivers have been loaded or needed for my multimedia controllers i have a dual tuner my sytem is a vgx xl 301 have you found any help or sorted the situation i could do with some help but it is doin my head in
@trebor75.
You have the Avermedia M115S TV tuner in your Vaio.
Have you tried installing the original Vista TV Driver that came preinstalled on your Vaio? I would guess it will work with Windows 7.
Under the Updates Tab here: -
http://www.sony.co.uk/support/en/product/VGX-XL301/updates
Download the Original Drivers Package and Extract the files to somewhere you can find them easily (C:\Drivers?)
Open the folder \\TV Capture and run the file 'InstallDriver.exe' to install the driver.
Hi thanks for your promt response is the avermedia tuner the one in the vgx xl301 sorry for being a bit thick ?
Yes, that is for the XL301.
Good Luck!
thanks for that i hope i can get the sound working on the computer now all the best , robert:smileyhappy:
Hi got the tuners working but still no sound ime using a hdmi cable and the settings areset to that but still no sound any ideas, thanks robert
Morning
Still no joy i have the tuners showing in device manager with no conflicts i have upgraded the sound driver i believe it is a sonic when playing a song i can see the bars moving up and down i have tried a line in from the dvi port still se thbars moving but still no sound there is nothing muted ime a bit lost know do i need a different cable or should sound come when the hdmi cable is in (i loaded the original drivers)
Robert
