I have a Sony Vaio VGX-TP3Z/B which i have had since last december.
I recently had to perform a reinstall of Windows Vista but i did then without backing up the drivers first so i had to redownload the drivers from the Sony Vaio website.
The problem i am having is that i cannot find the drivers for the tv tuner card so i cannot use Media Centre in Windows Vista.
Can you tell me where i can download the drivers for this system?
Thanks
Hi robbieride and welcome.
Have you reinstalled the original Sony version of Vista? If so all the drivers will install automatically from the recovery media.
It is probably not a good idea to install any other Operating System as all the drivers and utilities appear not to be available for download so the Vaio will not work properly.
No Sorry, i don't have the Sony Recover disk so that option isn't applicable, i used my own copy of Windows Vista.
Does anyone know where i can find drivers for the TV Tuner on this computer
As I said, I think the only way is to reinstall the original OS. Unless you have formatted the entire hard drive using FDisc, you can do this by tapping F10 during the boot sequence, when you see the first Vaio logo, to start the hard drive recovery.
You can then re-install whatever version of Vista you like once you have made copies of all the drivers and utilities.
The only other way is from another model Vaio or from the TV Card manufacturer. If you go to Device Manager, does it give a full description of what make and model TV card you have installed? I'm not sure what make the TV card is on your model.
You do NOT need a recovery disc to do a hard drive recovery - check page 32 of your Recovery and Troubleshooting Guide on using the Recovery Partition here: -
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2008Q2_TRG_EN.pdf
I apologise, you are right about Device Manager but you will need to know the details of your TV Card if you are going to look for an alternative source for the driver.
Don't expect me to reply again - I find your attitude offensive.
Hi.i had the same problem yesterday.i formatted the drive and put my own copy on.lost everything.there is no portion to rescue from but I searched through c: dev on new operating Vista system and found either old or windows old and everything was in there.i did not do any backups just installed Vista but worth a look as mine running perfect.searh managing through c: dev not use search box.good luck
