Music/File Organisation - NWa35
quarkrad
I have my music files organised by Album - but note that the sd card organises them by Artist.  Would the transfer process (from pc to Walkman) be quicker if I organisated the files on my pc by Artist?  Also, using MediaGo, I am using the import folder also as the library folder, is this OK or should I have a separate library and input folder (thus duplicating everything)?
2 REPLIES 2
EdwinaU
Moderator
Hi Quarkrad,
There's some useful information to help organise your music in the NW-A35 manual here. Hopefully this should help.
Best wishes,
Ed
Sonyvores
Contributor
It's just a way to organized the files. It's just logical and saving space to start with artists (main folder) since they can have many albums (many sub folder) while 1 album usually goes to 1 artist only.
The way you organized on Media Go doesn't change anything, it's just a better way to display the music file for you. Transfert won't be faster.
No issue with the import folder since the walkman scan the library everytime it restarts or synch
