Hi there,
I have just bought the Sony PCM M10 recorder after my trusty iRiver device gave up the ghost. I am now trying to transfer all the folders from this device and am having huge problems and so far haven't found any solution in the manual, that merely says "If you copy a music file one by one to the PCM recorder, you can display and play back tracks in order of copying".
I have far too many files in the folders to transfer each one manually. Can it be done with the Sound Forge Audio Studio software that is also provided? If so, how?
I am sure that I am not the first to have this problem and would really appreciate advice on how to create some sort of "nested" system like I had in the iRiver, using Windows Explorer. Is there some other magic programme that I need to install?
TIA for any help
Dianna
