Problems Installing Sonicstage
profile.country.en_GB.title
Beeva23
Until recently I have been using Sonicstage with my MZ-NH1 walkman and windows Vista with no problems. The last time I went use this the program would not recognise the player.
I decided to remove sonicstage and re-install hoping this would fix the issue, but no matter which version I download it will not install!!! I download the setup file, and run this as usual, go through the install wizard as usual, which all seems to work correctly. I am then prompted to restart the pc but when I do this there is no sign of the actual program or associate files anywhere??!!
I have also tried installing the original software from the Sony disc but this does not work with vista and when I try do update to the current version the wizard removes the old version but again does not install the new!
Any ideas gatefully recieved as this is driving me a little crazy
0 REPLIES 0
