Hi all
I have just got a new car and it has the Sony XAV-601BT fitted, I have installed a rear view camera, the problem I am having is that the camera does not activate when I go into reverse, the camera works when I go into the menu and tap the camera icon. I have downloaded the installation guide and looked on the wiring diagram and there is a wire that is labelled reverse in, should this wire be connected to the reversing live or the video feed line? if it does I have another problem the plug with the relevant wire is not with the unit, can anyone tell me which pin in the socket on the back of the unit the reverse in wire connects too or if a replacement plug with all the relevant cables can be obtained and where I would find one.
Any advise gratefully received
Thanks
