- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
stuck in guest mode - lost password
Disaster! Any way of overriding to back into main mode - preferably without losing everything?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
HI 1edpsy, as the password is there to prevent others form accessing your tablet the only solution to your problem would be to reset your tablet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How do I reset my tablet its a soney Xperia z1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
HI there
Do these instructions help :
(Taken from : http://www.android.gs/hard-reset-xperia-z1/ )
How to Hard Reset Xperia Z1 in a minute
Make a Software Hard Reset
- On your phone, go to settings.
- Tap the “backup and restore” option.
- Choose “factory data reset”.
- Up next press on “erase phone” and tap on “erase everything” in order to confirm.
Make a hard reset using the dedicated factory reset key
- The Xperia Z1 is coming with an un-removable battery which means that the hard reset button is located somewhere it can be easily accessed.
- In that matter open the cover of the SD card slot.
- There should be located a small red button.
- That is the hard reset key.
- Now press and hold that small red button for about 3 or 5 seconds.
- Your Xperia Z1 will be factory reset automatically.
Make a hard reset using Volume Up and Down buttons
- First off all, turn off your Xperia Z1.
- You can do this by pressing power button and choosing “power off” or by holding the power key for about 15 seconds.
- Now reboot by pressing the power button; when the LED notification light turns Pink (or any other color in that matter) press volume up or volume down button for a couple of times.
- Recovery mode will be entered on your Xperia Z1.
- From there select “wipe data factory reset”.
- Also, you can choose “wipe cache partition”.
- In the end from main menu of recovery select “reboot system now”.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I cannot get in my tablet its asking for my password which I cannot remember also I donot see a reset button I remove the SIM card slot and there no red button there. I need some help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I think it might be best if I point you towards the dedicated xperia forums instead. They should be able to assist you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Oh, ooops - yes mobile phone.
Tablet:
- Power down/turn off the tablet
- Press and hold "Volume +" for roughly 3 seconds
- While still holding "Volume +", then press and hold "Power" for an additional second.
- Use "volume -" to arrow down to the factory reset option.
- Press "Power" to select this option.
- On the next screen use "volume -" again to navigate to the YES option to confirm this is what you wish to do (all data will be erased).
Thanks Nobody-In-Particular : must read question more carefully
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
LOL
Yes unfortunately this will erase all data on the tablet (unless you have your photos, movies and music stored on an sd card in the tablet - in which case take that out before the reset too!)
