Z3 Tablet stuck in bootloop
DanielxC
I have a Z3 tablet compact Wi-Fi, stock, no root, that is in a boot loop at the black and white Sony logo. Repair using Xperia companion is successful, but the loop continues. I've also tried flashing stock ROM using Flash Tool. Again, no errors encountered but the boot loop continues.
Any thoughts? I've also tried running the battery down to no avail.
Thanks,
Daniel
4 REPLIES 4
profile.country.PH.title
MarlonUk1
1. Charge the device 2-3 hours using the wall mount charger. Remove all accessories like SD card etc. Ignore. Boot loops
2. Try repairing again using Xperia companion. Preferably using another computer or a re installed one.
guneet21
According to Sony Xperia Z3 Manual to get rid of this issue do as following:
  1.  First of all switch off your tablet.
  2. Hold volume up and power for approx 10 seconds
  3. Start PC Companion .
  4. Choose Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions.
  5. When prompted connect your phone still switched off holding volume down.This should start the repair or reformat process
  6.  If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP.
I hope this might fix your issue. For more deatils you can also check manual.
Franz_
I've had this problem.
I've tried to repair software using Xperia Companion for a few days, unsuccesfully.
I noticed same water condensation on the memory card when i removed it.
I put the device in a warm place with all the cover totaly open for few days, to evaporate internal water condensation.
I've tried to repair software using Xperia Companion, this time succesfully.
Jycy
Hi to all,
I'm having the same problem. The tablet is stuck in bootloop and unfortunately I cannot even use Xperia Companion cause it seems it needs Transfer Multimedia (MTP) to be accessible.
Moreover, there is a secure pattern mode so anyway I cannot do anything.
Any helps ? besides the "condensation problem", someone has got any solution with this kind of booloop problem ?
Thanks for your help Slightly_smiling_Face
