cancel
Showing results for
Search instead for
Did you mean:
Aqwuisicao de Duisco USB HD compativel com Bravia KDLEX720
profile.country.pt_PT.title
jmsm25
Bom dia
Alguem me pode informar sobre que tipo de disco externo USB (caracteristicas... marca ...) poderei adquirir que seja compatível com Bravia KDL 40ex720? Que formato deve ter o disco para estar compativel com gravação HD... FAT32? NTFS ?
Cumprimentos
Obrigado
jmsm25
5 REPLIES 5
V57...
Contributor
Caro jmsm25,
De acordo com a Sony, este é o disco externo aconselhável...HD-PG5U...
First external hard drives from Sony offer reliable data storage and expanded home entertainment options
12 July 2011
HD-PG5 series drives are compatible with BRAVIA® TV and other devices by Sony
500GB portable external hard drives with stylish design
High-speed transfers via USB3.0 with supplied Data Transfer Accelerator software
Record HDTV programmes from BRAVIA® via USB connection
Direct Copy from Handycam® camcorders (HD-PG5U)
Includes Password Protection Manager, Backup Manager and FAT32 Formatter software
HD-PG5UB hard disk drive
The first ever range of external hard drives from Sony keep your precious data safe, while offering a range of exciting new home entertainment experiences.
With a generous capacity of 500GB, the new HD-PG5 series offers plenty of space to store and safeguard your videos, photos, documents, digital music and more.
The HD-PG5U connects via USB with compatible BRAVIA® models, allowing direct recording of HD television programmes from the TV’s tuner or connected cable/satellite service. The supplied USB adaptor cable also allows easy ‘PC-free’ transfers of video footage from compatible Handycam® camcorders with Direct Copy function, including the new DCR-SX21E and DCR-SR21.
PlayStation®3 users can connect the hard drive via USB and view stored AVCHD videos and photos via the ‘Filmy’ application – with no PC needed.
Available in a choice of black or white finishes and weighing a travel-friendly 180g, the stylish drives co-ordinate beautifully with your PC, BRAVIA® or PlayStation®3. The smoothly-contoured case is finished in a scratch-resistant paint layer that keeps your drive looking good for longer. The minimalist design is enhanced by a single blue LED that indicates drive activity.
Connection to your PC is via a single USB cable, with no separate power adaptor needed. Support for USB 3.0 SuperSpeed assures blazing data transfers up to 3x with compatible PCs. Even if you’re connected via USB 2.0, pre-loaded Data Transfer Accelerator software also doubles effective transfer rates to slash backup times when you’re in a hurry.
All HD-PG5 models are ready to use with a generous suite of security and backup applications. Easy-to-use Password Protection Manager software uses powerful 256-bit security to safeguard your files against unauthorised access. Just key in your personal password to lock or unlock data when the HD-PG5UB is connected to any PC. Backup Manager software takes care of protecting your precious files with automated scheduled backups.
Supplied FAT32 Formatter software allows re-formatting of the drive from NTFS, to support Direct Copy function with Handycam® or playback with PlayStation®3.
The new HD-PG5 series of 500GB external hard drives by Sony is available from mid July 2011 in United Kingdom, France and Germany only.
Cumprimentos
jmsm25
Caro V57 boa tarde.
Mais uma vez fico grato pelos seus esclarecimentos
Obrigado
Cump.
Jm
V57...
Contributor
Disponha sempre...:smileywink:
Apenas uma chamada de atenção...apesar de já ter sido apresentado há cerca de 8/9 meses, não sei se estará disponível neste momento em Portugal...
Quer-me parecer que apenas começou agora a ser distribuído pelo que me pude aperceber por este site...
Cumprimentos
jmsm25
Ainda assim, será que a connectividade com outras marcas neste tipo de produto pode representar algum tipo de incompatibilidade ? WD, Lg etc ?
jmsm
V57...
Contributor
Caro jmsm25,
Se possuir um disco externo (até emprestado) e de preferência com corrente própria e formatado em NTFS, tente fazer a experiência.. .acredito que irá funcionar....mas só experimentando...:smileyconfused:
Cumprimentos
