Arrow Launcher cannot uninstall!!!
Emirkcby
When I try to uninstall it and try to remove it's permission on device manager menu in security settings, settings brokes suddenly
15 REPLIES 15
Emirkcby
You can install and try Arrow Launcher if you think you can handle that problem 😅 you should see what happens by yourself for understand it exactly
Jonas
Master
Hello again! Slightly_smiling_Face
I just installed the Arrow Launcher in an Xperia X with the latest software installed and I had no troubles uninstalling it.
What I did was that I went into Settings > Lock screen & Security > Device administrators > tapped on "Arrow launcher" (the checkbox next to it was not marked) and in the bottom of the next screen there was an option called "Uninstall" and the app/launcher was uninstalled.
If you go back to Settings > Lock screen & Security and tap on "Clear credentials", try uninstalling the launcher again.
Let me know how it goes! Slightly_smiling_Face
Emirkcby
I've tried that already but setting crushed
Here is video of I am trying to uninstall the application and what happens
https://drive.google.com/file/d/0B9Z7pIQtDxQWZzNvVFY1cllNRUk/view?usp=drivesdk
Jonas
Master
Thanks for the video! Slightly_smiling_Face
If you go to Settings > Apps > 3 dots in the top right corner > Show system > Settings > Storage > Clear data.
Try uninstalling the launcher now and see if you experience the same behaviour.
Keep me posted! Slightly_smiling_Face
Emirkcby
İt worked. Thanks a lot 👍🏻
Jonas
Master
You're welcome! Slightly_smiling_Face
Let me know if there is anything else I can help you with and have a great day! Slightly_smiling_Face
