I have an Xperia X Compact (model F5321 running Android 7.1.1). A few months ago it started exhibiting a very unnoying problem. When I use an app and want to do something within this app that requires a confirmation, the confirmation pop-up window that appears is unresponsive, so I cannot either confirm or cancel this action. Examples:
I have searched the Internet, but could find a solution to this issue. Any ideas will be appreciated!
Happy New Year!
Hi @Kot-Begemot
The best solution is to wipe out everything.
In other words: do a software repair with Xperia Companion.
You can keep searching and it would indeed be nice if you would find the answer.
Better start all over.
Precautions:
Read on this forum Information -> FAQ
Explore the Support app and learn.
Synchronise everything you have with Google (settings->accounts->[email protected]
In your messenger apps like Signal and WhatsApp goto settings an backup your conversations.
Be shure that you remeber your [email protected] password
Create an extra backup inside Xperia Companion
Carge battery to >80%
Do the Software repair.
Do not restore the full backup.
By restoring everything you might restore the problem as well.
Just install the most needed apps.
Your device will reward you with renewed swiftness.
Tell us if you succeeded.
