Home screen pic shrinks on own
godfrey1
Hi
I have the Experia A1 ultra and find my home screen pic will shrink down to a small size on its own , does it maybe 2 times a day , don't know y it does this and only way I can put it bk to normal size is restart the phone , any ideas . Many thanks
10 REPLIES 10
Uliwooly
@godfrey
Does this happen with a preloaded wallpaper or your own picture?
godfrey1
It happens with my own picture
Dawg1
I have the same problem
Garej
I have the same issue. The picture will move, not shrink so most of the picture is cut off.
Dawg1
If you press the Home screen in a blank place you will be offered to select a new home /lock screen picture just change it, then do it again with the picture you had before.
This does not fix it long term but saves restarting the phone, I have the same problem, but not twice a day properly every other day
Taygen
I have the exact same problem. So does aa friend of mine who has the same phone. Would be great to get a response from Sony.
Turkeyozgur
MonthsI have The same problem
slumdawgrsa
This happens when I load 4k wallpapers, only otherwise I have no problem with my standard boring wallpapers.WWill. Be trying some 1080p later and get back.
slumdawgrsa
So far so good. Haven't shrunk yet. Fingers crossed 1080p wallpapers for now, hopefully 8.0/8.1 update will sort out issue
