How to speed xa1 plus
Sudhan_23
3 REPLIES 3
Martin1
Enthusiast
Hi @Sudhan_23, let me see if I can help out here.
I am not really sure on what you mean by your post, please do elaborate your question as much as you can and I will do my best to assist you!
Sudhan_23
My android running too much slowly, how solve it problems.Then how i take perfect pictures and send me perfect camera settings.how i increases charging speed?
Martin1
Enthusiast
Hi again @Sudhan_23,
Have you checked whether there is a software update available? Find and tap Settings > System > Software update. It might also be a good idea to check for available app updates. Open the Play Store > Tap the three horizontal lines in the top left corner > Tap "My apps and games".
Have you tried rebooting your phone in safe mode to see if the menus are running slow there as well? Safe mode is a troubleshooting mode where all apps downloaded from Play Store is temporarily deactivated, that way you can see if there is a downloaded app causing the phone to act slow
The easiest thing to do to improve the charging rate is to use a quick charger instead of the charger that came in the box (UCH20). As it is always recommended to use original chargers, I would suggest that you try UCH12.
Regarding "perfect camera settings", it is practically impossible to say which settings are optimal due to the fact that one set of settings works better for a specific kind of surroundings and while another set of settings work better for another kind of surroundings. For more information on how to get to know the camera in your XA1 Plus, click here. There is also a great general guide on how to take better photos in the tips and tricks section of this forum. Please check the link below.
/t5/Tips-Tricks/Using-Your-Camera/m-p/1344273#M372
I hope that helped! Let me know if you have any further questions!
