Mirror effect
MANON2
Mirror effect
Bonjour lorsque je prend une photo ou selfie avec la caméra frontal ma photo a la fin fait un effet miroir je n'arrive plus à le desactiver en sachant qu'avant ça ne me faisait pas ça du coup sur snap chat ça me fait la même chose pouvez vous m'aider et me dire dans quel paramètre désactive ton ce truc ?
Hello when I take a photo or selfie with the front camera my photo in the end is a mirror effect I can not disable it knowing that before that did not do me this on snap cat it makes me the same can you help me and tell me which setting turns off this thing? - GT
1 REPLY 1
Martin1
Enthusiast
Hi @MANON2, let me see if I can help out here!
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
When using the camera of your Xperia XA1 ultra to take a selfie using the front-facing camera, the photo will be a mirror image. This is by design and there is no setting available enabling you to change this. It is however possible to edit the mirroring of the photo. To edit the mirroring of a photo, please follow the steps below.
  1. From your Home screen, tap the Application screen icon.
  2. Tap Album, then tap the photo you want to edit.
  3. Tap the edit icon, then tap Photo editor.
  4. Tap the crop icon, then Mirror.
  5. To save your changes, tap Save.
I hope that answered your question!
