Pdf files
EgriDino
Pdf files
Could You please suggest an app for me that can actually open pdf files? Wps office, Pdf viewer and Pdf reader couldn't (most of the time) .
Thanx so much.
1 REPLY 1
Jonas
Master
Hi @EgriDino, welcome to our forum!
I use the inbuilt one in Google Drive and that one should be pre-installed in your device, it's just called "Drive PDF viewer" but it's not an external application as it is built into Google Drive.
If you open up the application called "Files" in your device > browse to the pdf file(s) > press and hold on it > tap the three dots in the top right corner and tap on "Open with", you should have this application as an option.
You also have the classic Adobe Acrobat Reader available in the Google Play store if you prefer to use that one.
I hope that helps! Slightly_smiling_Face
