Is there a way to increase the number of rings before transferring to voicemail. My phone rings 3 times then transfers. Thanks
Hi @Psycho1,
You can try and call your voicemail number and see if you can edit this yourself, but if you can't you will need to get in touch with the operator as they are responsible for the voicemail service.
I hope that helps!
