RadioFM
Rocío10
RadioFM
Hola. No puedo oír las emisoras en RADIOFM. Ni en altavoz ni con auricular, aunque estas se sintonizan y al parecer estarían funcionando.
Hi. I can't hear the stations on RADIOFM. Neither in loudspeaker nor with earphone, although these are tuned and apparently they would be working.
gt
1 REPLY 1
Martin1
Enthusiast
Hi @Rocío10, let me see if I can help out here!
Your post has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
Have you tried using another set of headphones in order to see if the radio works better with other headphones? Also, try clearing data for the FM Radio-app. This will reset all settings for the app in question which might do the trick. Find and tap Settings > Apps & notifications > Show all XX apps > FM Radio > Storage > Clear data > Restart the phone.
Another thingt that you can try is to restart the phone in safe mode to see if the FM radio app works better there. All apps downloaded from Play Store is Stemporarily deactivated while in safe mode and by doing this, you can see if this behaviour is caused by a downloaded app.
Try these measures and let me know how it goes!
