Buenas.
Tengo un xperia ax2 y no tiene la opción de pasar las aplicaciones de la memoria interna del teléfono a la tarjeta SD, esto hace que sus 32 gigas de almacenamiento interno se queden un poco cortos.
¿Se contempla alguna actualización con esta función?
Good.
I have an xperia ax2 and does not have the option to pass the applications from the internal memory of the phone to the SD card, this makes its 32 gigs of internal storage are a bit short.
Is any update contemplated with this function?
gt
@Simonmmmmm, I understand and it would of course be good if all apps could be moved to an SD card, don't get me wrong!
I was just trying to give some small suggestion, and yes, it has to reload some of the cache and it will depend on the application how much it will affect the performance. I was just thinking if you had never done it and you had a lot of cached data in certain applications, you could free up some memory by clearing the cache.
I'm just glad that I can save my downloaded podcasts and offline play lists in the music app I use to the SD card, or else I would struggle with having enough internal storage as well.
У меня есть один вопрос. Как переместить приложение на SD-карту? Спасибо заранее.
I have one question. How to move the application to the SD card? Thanks in advance. - GT
Hi @her5na, welcome to our forum!
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
Please have a look at my reply on the link below and you will find an answer to your question!
/t5/Xperia-XA2/Save-applications-on-the-sd-AX2-card/m-p/1362435#M1566
