Xperia Xa: Heating while charging
Danyeinne
hello! Good Afternoon, I just bought this morning my Xperia Xa Ultra and I am charging it for the first time. I would like to ask, is it normal that the device is heating while charging? (P.S the device is OFF) Thank you for the response.
5 REPLIES 5
Elyssa
Hi. I  bought mine 2 days ago and the same thing happened....  In this two day I noticed that the XA heating while I play games and when i use the divice while i charging it...
When I use the divice In the course of the day it is slightly warmed...
I searched info in websites and it seems " is common"  in this phone...
I hope Sony do something about it, because the phone is nothing cheap to have these problems
Uliwooly
@Danyeinne @Elyssa
There's nothing wrong with your phone.
Elyssa
Nothing wrong???
So heating is nothing wrong?
What a answer....  There's many things wrong with this phone...  And I've been discovering them in 2 days....
And i repeat  Sony should do something about it, because the phone is not cheap to have those problems...
Uliwooly
@Elyssa
Charge any phone/electronic device and it will heat up, that's normal, more so if you are using it at the same time.
Also, this is a USER BASED FORUM, which means, that you will read other USER'S OPINIONS/SUGGESTIONS.
You can contact Sony directly >>> Local support
Elyssa
I know what a forum is.
And it means you post something expecting get an useful answer and detailed.
Anyway...
I know that phones can heating
I got an old LG Bello
But it only get heating few times when I used iit hard while charging and the room temperature was really hot.
I used the XA in a climate room the temperature is less 20°. With airplane mode  WiFi turn on...  And whatch some videos...  WhatsApp and chrome few...
Therewith the batery of the phone least 7- 10 hrs maximum with a minimum use....  You think nothing is wrong with the phone??
