Good evening
Since Today my Xperia Xa is stuck in a boot loop after I restarted it after a long time.
I tried "Xperia Companion" but it doesn't fix it. "Xperia Companion" states that I should be able to start my phone, but it doesn't work.
I thank you for your help
sincerly Me
@SwagLord
Hi just try to do factory reset and it should work fine
Thank you so much. It worked!
Thks. You're life saver! Sa-ti dea Dumnezeu sanatate!
Thank you very much for support through this post.
Its really work.
My Phone Sony Experia XA. problem stack boot loop (SONY) I use Sony Companion and Flashtool . but can't fix.
This has happend to be twice and on both instances my phone went into a restart loop. After repeated restarts, the phone started up. When this happens, identify the last installed applications and uninstall them one by one until you identify the one that is causing the phone to reboot. As long as the faulty app is installed and running the phone with intermittently go into the reboot loop.
hi there to all.
i had and im still having this problem due after making the repair thing with pc companion, still in some moments when im using the phone - he freezes and goes black as a restart and enters in boot loop restart mode. yes i can turn it off by power button + vol+/- pressed and then it starts normally like nothing happened till to the next his moments of freeze, and thats not so cool to check if your phone goes into loop mode to be able to get a call from someone (like to be sure if your phone is on and people can find u at phone) what could be the problem for the loops? or what should i do?
thanks in advance.
I guess your experience is with a clean device?
Did you think of not restoring the backup?
An unstable app may cause trouble.
Reinstalling everything can re-introduce trouble.
