my xperia ion keep on turning off so i decided to update my xperia ion with sony update center i have installed it and followed all those instructions but updatecenter said that my phone battery should be greater than 50 % as it take lot of time to download the necessary files i simple kept it like that i thought it will charge mean while and green light is on it have started downloading necessary files mean while i went to sleep as it said that the estimated time for downloading time is three hours after i wake up i found that it have completed the update and asked me to disconnect the cable and switch on the phone i did the same but i cannot turn it on noting is happening when i try to hold the different combination of power and volume keys when i connect my phone to wall charger it is showing a simple blinking red light after charging it for 25+ hrs it is showing a constant red light ... idont know what to do pls somebody help me......
well that is not the thing that iam actually asking for i just wat to switch on my phone it isnt responding to any of the power and volume key combinations and it is charging from 25 hrs and still i cant get a green light i even cant connect it to my pc... pls tell me what to do
Connect your phone to a wall charger > press and hold power & volume up for 10 or more seconds > let it charge for 2 or 3 hours > if that doesn't work you will have to take it to a Sony repair center
