I tried using 3 different chargers I also tried plugging it to my computer. However it still didnt work my phone wont charge. my phone turns on but it doesnt recognize any charger pls help asap
Need help guys:smileycry:
I have the same problem
If something works for u tell me:))
You have to take your phone to a Sony repair center
Im still waiting for a good answer
If you turn the phone off and on again it will work. I think the problem arises if you have Low battery mode turned on in the power management saving modes in settings. Looks like it disables the phone from recognising a charging cable is plugged in when it get's below your percentage setting. Anoyining as that is when you need to charge it the most.
