Hello,
i have a very strange issue with my SD-Cards. Every picture on it appears only half rendered, or with yellow, grey, green wrong rendered pictures. It has no dependence on my picture viewer (Fstop). Pictures which i send on whatsapp are also grey, or half rendered. I only have the possibility to use the internal storage as memory.
I tried several SD-Cards, my last was a Samsung Pro Series, the first one a Sandisk Ultra. The issue still exist.
So what could be wrong here?
Regards
Yes, it does not depend on the camera.
Copied JPGs from my RX100 III have the same issues. Every picture on the SD-Card appears buggy, even thumbnails.
Hi @Sze, I'm sorry to hear this.
Since you have already tested different SD cards I would suggest that you perform a software repair using Xperia Companion, as @Viridis already suggested. If that doesn't help you should contact your Local support team for more information on how you can proceed with this.
Okay, i will try it that way.
I also benchmarked the Sandisk Ultra with A1 SD Bench.
z5 Compact:
Read: 41 MB/s
Write: 18 MB/s
Xperia XZ:
Read: 10MB/s
Write: 18MB/s
Something seems to be wrong here.
Feel free to keep us updated.
Hey arvin
I cant tell you something about my results yet, because i ran yesterday into a google security feature. Yesterday i changed my google password and my login method into 2 factor auth. I did not know that i should not wipe a device within the next 72h.
Of course i did it
(Sony Software Repair)
The initial phone setup process requires, after a factory reset, a google account which was used before. Its impossible to skip the google login procedure, so i have to wait till sunday.
But beside the picture issue, my sd-card was very slow. I used to store my osmand (offline navigation) maps on the SD-Card, and the performance of the map rendering was very poor. My z5 compact was a way more faster.
