Screen is flashing
cool10
Screen is flashing
As i am facing problem of automatically flashing of screen.And it also showing me power off message for every second..
I m unable to open application as its flashing screen and that pop up message.
When i Press power off button to lock then also it flashes.I have to press for 3 4 time sometimes to lock..
Please help me as soon as possible..
Thanks in advance..
1 REPLY 1
Hampus
Champion
Do you experience the same problem in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Should the problem occur in safe mode, I suggest that you perform a software repair on your unit via Update Service:
http://www.sonymobile.com/global-en/tools/update-service/
Download and install SUS to your PC, follow the instructions that appear.
If the problem persist after a software repair, I would recommend you to contact your local support team to get information regarding nearest service center and how you should proceed in this case:
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
