Xperia Ray can't activate wifi
Oliver777
I have Xperia Ray running ICS 4.0.4, and trying to conect wifi says "activating" but it doesn't activate.:smileysad:
Problem is, I can't use wifi because its between active an inactive.
I had check all Apps and under Settings/Apps/all apps, there is AntHalService disabled, I tried to enable it, but all buttons are inactive and I cant do anything.
I have a lot of apps and if I repair the system with pc companion I will lost all cause I can't do a backup, so would be nice if anyone knows any other way to solve it.
I add some screenshots
Thanks
2 REPLIES 2
Sam
Legend
Legend
Unfortunately with a problem such as this an update is really the only way to go. You could download one of many applications on the Playstore that would allow you to backup the applications before going ahead.
What are your thoughts about this forum? Let us know by doing this short survey.
Nverma
Hi Friend,
I came across this post with a similar issue I am facing with my Ray right now.
Could you please help me with what you did to fix the issue then?
best regards,
Nikhil V
