Z5 compact took in wanter through the Strap hole
Johny340
I noticed air passes through my strap hole into the phone... I put my phone in water before i discoverd this and noticed both cameras fogged up which took a week + to clear out... Is the strap hole ment to act like a vent?
10 REPLIES 10
Uliwooly
@Johny340
they are unrelated, you should get your device inspected by your Local support, request a vacuum test.
Johny340
Will have to do that in another country there's no local support in zimbabwe
Emir1
Hero
Hi @Johny340,
The steam inside the phone body will be condensed when you expose the device to cold water, which is a normal physical phenomenon. Such condensation is usually very mild and will not have bad effects on the phone. The mist will naturally evaporate when the phone returns to normal room temperature. Please try to avoid sudden temperature changes of the phone to prevent the condensation inside the phone. The strap should not be a way for water to enter your device.
Should the condensation persist or if you suspect that something may be wrong with your device, then I strongly recommend having your device sent to an authorized service center in order to have it examined as @uliwooly suggested above. For assistance in sending it in, you may get in touch with your Local support. Slightly_smiling_Face
Johny340
I am sure the strap hole is a defect... When the steam cleared water droplets where formed as if water went in... The water damage indicator slightly tuned pink round the edges and my vibration was lost it only just came back a week after the water droplets cleared.... Do you think its still waterproof or i have to get another one
Emir1
Hero
If the moisture indicator went off inside the device then I would strongly recommend you to have your device delivered to an authorized service center in order to have it examined, especially since you noticed features not working. Slightly_frowning_Face
If you're from Zimbabwe, try emailing the local team there at [email protected] for instructions.
Johny340
Thank you for that into will email them right away🙂
Emir1
Hero
That sounds good, let me know how it went! Slightly_smiling_Face
Johny340
Not good 😕 the inbox is no long supported so wont get any info from on how to go about my problem
SuperMan1986
i also noticed that
when i checked "air pruessur via *#*#SERVICE#*#*
to check water proffing
when i pressed the strap hole the numbers moved (when i press genlty the screen (like now there is real waterproof vecom)
so i put there ductape ,but! when i did it the spakers sounded afuwall
so i removed it (till i need it)
ps
sry for my english
