annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Navigation bar doesn't respond
Z3C_user1
Visiteur
Hi, I have been using my xperia Z3 compact for 2 years. Suddenly, the navigation bar stopped responding. Home button doesn't work when I tap on it nor do the back button and the button for recent apps. I restarted the phone a few times but that didn't help. Please help me.
Balises (3)
14 RÉPONSES 14
CameronT
Héros
Hi @Z3C_user1, welcome to the community. I am sorry to hear about this issue Slightly_frowning_Face
Based on the information provided I recommend you try running a software repair using Xperia Companion.
If it still does the same thing in after the software repair then I recommend you contact your Local support team to arrange repair.
SnusMumr
Visiteur
Hi, I have a similar issue. My navigation bar buttons stopped working. But I can tap on the area in lock screen and everything works fine, I can start camera app and unblock screen. Sometimes buttons start working after some time when phone is unblocked. But most time don't.
I haven't tried softweare repair yet. But I found a workaroud. You can try to turn on "Glove-mode" in display settings. It doesn't 100% fix it, but at least something.
profile.country.US.title
Qatrium
@Z3C_user1
@SnusMumr
You have installed an app that has the permission to draw over other apps. That's why you can access the navigation buttons in lock screen, and probably also in safe mode. Uninstalling apps one by one until the issue disappears is the only way to figure out which app does this.
SnusMumr
Visiteur
@Quester
I tried booting in safe mode and the problem persists.
I didn't install any applications for two months, I think. However, can I see a list of applications, that could draw over other apps?
SnusMumr
Visiteur
So, software repair didn't help.
Uliwooly
@SnusMumr
time to get it inspected by your Local support
Z3C_user1
Visiteur
@CameronT
@SnusMumr
@Quester
Thanks everyone for your help. I will try these methods to solve this problem. For now, glove mode works just fine.
polodipolo
Visiteur
Hi Z3c_user,
Could you resolve the problem?
I had similar issue with the notification bar / pull down menu. It stopped working for several months but then started working again after some update.
Now the buttons on the bottom have stopped working.
I do not think that it is a hardware issue, since:
1. The respective part of the touchscreen works flawlessly in other applications and in the lock screen.
2. I had similar issue with the notification bar / pull down menu. It stopped working for several months but then started working again after some update.
Best,
polodipolo
Ade23
Visiteur
Woke up this morning to find my return arrow not working, also my home button. I have shut down and restarted the phone a few times but fault persists. Any ideas?
