so i purchased my Xperia Z C6603 and it automatically worked on AT&T's 4G network which was awesome,
but because their 4G internet packages cost an arm n a leg, i switched to T-mobile today& now im stuck on Edge/no service
is there anything i can do? or am i screwed this month
my bad, yeah it is not going to work, why? simple
C6603 HSDPA 850 - 900 - 2100
Tmobile USA use 1700-2100 (both are needed)
so you will be stuck on 2G/Edge with Tmobile
now it seems that 1900 is for 3G and 1700 & 2100 is for LTE (combined)
C6602 HSDPA 850 / 900 / 1700 / 1900 / 2100
the C6603 doesn't work with AT&T's 4G, at least not with LTE, it does work with their H (3.5G) network.
do you have the correct Tmobile's apn settings?
when i put my ATT sim in the phone, they automatically recognized what phone i had and because it was working with their 4G, they added a $30 3GB internet package.
as for t-mobile,the settings they gave me were just "epc.tmobile.com"
i tried downloading settings automatically to see if it helped but it was the same settings. 😕
try this
settings > more > mobile networks > apn > menu > add New > enter this
APN: epc.tmobile.com or fast.tmobile.com (for LTE devices)
Proxy:
Port:
Username:
Password:
Server:
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy:
MMS port:
MMS protocol: WAP 2.0
MCC: 310
MNC: 260
Authentication type:
menu > save
restart your phone
still running EDGE.
When i try searching for avail networks, only T-mobile 2G comes up ._.
so i bought the wrong phone if i want t-mobile? lol
dangit. i guess ill try to switch back to ATT next month.
Thanks for the help!
anytime
| USA Carrier | Voice Frequencies | 3G | 4G | 3G Technology | 4G Technology |
| AT&T | 850 MHz, 1900 MHz | 850 MHz, 1900 MHz | 700 MHz, 1700/2100 MHz | GSM/HSPA+ | LTE |
| MetroPCS | 1700/2100 MHz, 1900 MHz | 1700/2100 MHz, 1900 MHz | 1700/2100 MHz | CDMA/EVDO | LTE |
| Sprint | 800 MHz, 1900 MHz | 1900 MHz | 800 MHz, 1900 MHz, 2500 MHz | CDMA/EVDO | WiMAX (2010–present) LTE (2012–present) |
| T-Mobile USA | 1700/2100 MHz, 1900 MHz | 1700/2100 MHz, 1900 MHz | 1700/2100 MHz | GSM/HSPA+ | LTE (2013) |
| Verizon | 850 MHz, 1900 MHz | 850 MHz, 1900 MHz | 700 MHz, 1700/2100 MHz (Planned) | CDMA/EVDO | LTE [3][4] |
| U.S. Cellular | 800 MHz, 1900 MHz |
I have the 6602 purchased at the Sony store in the US and as far as I know you cannot get LTE with AT&T. The best I can get is H+. Also, my understanding is you will be able to get LTE on T-Mobile when it is released by that carrier.
Indeed its not going to work with AT&T's LTE at all
Don't forget to give Kudos
