Hi tjtruckie,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
When a handset uses a call diversion function in most cases it has been implemented from the network carrier, as network carrier codes are required to assign call diversion options.
Check the following, Menu > Settings > Call Settings > Call forwarding > make sure everything is disabled.
I then suggest contacting your network carrier and inquire with them about your account settings for call diversion.
Let us know how you get one.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
Hi tjtruckie,
