Xperia 5 V: USB charging will not work in my new VW Golf
profile.country.FI.title
tos-82
  • Car / head unit make & model: Volkswagen Golf GTE 2025, MIB4
  • Phone make & model: Sony Xperia 5V (XQ-DE54)
  • Android OS version: 15
  • Android Auto app version: 13.9.651014-release
  • Google Play services version: 25.10.36 (260400-739992411)
I have previously Golf 2021 MIB3 infotainment, and AA/Charging worked fine.
Now with this new Golf I cannot charge my phone anymore via cable, data connection will work ok.
Same cable fast charging will work with my old Xperia 5 II, samsung A32 and my friends iphone with usb-c.
Fast charging will works also DJI drone battery hub.
I tested this also VW Passat 2025, same problem.
5 REPLIES 5
tos-82
Charging in works also with old Nokia 8.
Xperia 5V fast charging works with home charger Sony UHC-32, and from my PC usb-c power delivery ports - so there is not wrong in cables.
MaggieGreene
Hi @tos-82, did you try a different cable with the Xperia on your car? Does it still not work? Can you try a different Android phone through the same charger of your Xperia through your car and check if it will work? Also, can you try the same cable on a different car through the Xperia 5V?
tos-82
Thank you for your help.
I have tested 3 different cables, one of them was sony cable from my old xperia 5 II.
Older android phones will work well, like Nokia 8, Samsung A35 and Xperia 5 II.
Iphone with USB-C will use fast charging on my car.
I tested charging Xperia 5V from vw dealer (Passat 2025, same infotainment system), Settings says not charging.
Im glad that wireless charging is fast enough, but my phone get hot.
I tested also developer mode and other usb settings, no luck.
tos-82
I think that "no charging" feature came aftet Xperia system update 67.2.A.3.2.
I got the car at 12.3.2025 and Xperia updated itself at 24.3.2025
tos-82
Update 67.2.A.3.16 came today, it did not fix the problem.
